Exhaust gasket fit problem - LegacyGT.org
Go Back   LegacyGT.org > Legacy Technical > Engine, Power, & Performance
Old 02-03-2013, 12:39 PM   #1
relative4
Default Exhaust gasket fit problem
Reassembling the exhaust system on my '05 LGT, and the flanges connecting the rear pipe to the mufflers have bowed out to the point that, after tightening the bolts, I can see straight through. How do I deal with this? Double up on the gaskets, or what? Thanks!
relative4 is offline   Reply With Quote
Old 02-04-2013, 10:11 AM   #2
I've had something similar before. I took a hand held grinder and shave/grinded down the ends (where the bolt holes are) of the bowed flange until the center two pipes connected.
