91 legacy project - LegacyGT.org
Go Back   LegacyGT.org > Legacy Owner's Lounge > General
Old 02-11-2013, 11:38 AM   #1
91 Lego
Default 91 legacy project
Still looking for ideas for my Fwd legacy project i don't just want to do the 91 turbo swap i want somthin more any ideas?
91 FWD LEGACY PROJECT
91 Lego is offline   Reply With Quote
Old 02-11-2013, 12:05 PM   #2
91 Lego
Why is it i never get an answer
Old 02-11-2013, 12:10 PM   #3
91 Lego
Echo echo
e
c
h
o
Ha I've always wanted to do that
Old 02-11-2013, 12:46 PM   #4
Because this site is slow.
What do you plan on doing with the car?
Old 02-11-2013, 01:03 PM   #5
91 Lego
Weekend warrior/ Daily driver.
sleek quic and original I'm just having problems with the fwd trans and awd convo is out if the question I'm wondering whats gonna bolt up to that
Old 02-11-2013, 03:18 PM   #6
That's the problem is Subaru hasn't made a FWD in a long time, so there's not much you can do there besides custom work, or convert it to AWD. Not sure if your model year can be converted with a drive shaft down the center.
Old 02-12-2013, 09:30 AM   #7
91 Lego
Negitive the damn thing refuses to start any how I've checced everything and to no avail after the repairs i did it turns over but it will not start
Old 02-12-2013, 01:39 PM   #8
How long has the car been setting? What kind of work have you done to it?
1) Pull the spark plugs and see if they are sparking when the motor is being turned over.
2) Take off the fuel line next to the fuel rail and see if fuel comes out when the motor is being turned over.
If those check out fine, next run a compression test on each cylinder.
Old 02-13-2013, 01:21 PM   #9
The amount of traffic here is very light. Check legacygt.com for more input.
Old 02-13-2013, 06:42 PM   #10
Also check Subaru Legacy International - http://sl-i.net/FORUM/
You'll also want to give NASIOC a try.
