Exhaust Silencer Removal - LegacyGT.org
Go Back   LegacyGT.org > Legacy Technical > Engine, Power, & Performance
Old 04-05-2006, 04:03 PM   #1
jedimaster
Default Exhaust Silencer Removal
I wasn't happy with the XT being as quiet as it was. So I decided to remove the exhaust silencer- I used a pipe cutter to score and remove the silencer:
After that, I unbolted the pipe and put it on a bench to start cutting and measuring.
I used some simple exhaust clamps and a piece of straight pipe to fill the gap left by the silencer- remember, measure twice, cut once...
This is what the silencer looks like:
And here it is looking down into it- it's hard to tell from this pic, but the pipe goes straight through and there's a lot of baffling that traps sound.
Here's the final product:
Impressions: Upon startup, there's a nice little "thunder crack" as the beast comes to life. Once settled into idle, it sounds like it means business without sounding obnoxious. It actually sounds a bit like the Prodrive my buddy had on his WRX. On my own former WRX, I had a Bosal 3" catback on with no silencer and it was loud, obnoxious and droned like crazy. This is nothing like that- no drone, I suspect due to twin mufflers. It's not overly loud inside with the windows shut either, which was a concern. I can't say that it added any power- if it did, it's not much, but it does sound pretty damn good.
So overall, 45 minutes worth of work and very worth it. There goes the rest of the weekend project though- I had planned to replace the mufflers, but I'm quite pleased with how the car sounds now and anything louder might be too much.
jedimaster is offline   Reply With Quote
Old 04-06-2006, 08:36 PM   #2
ih8vtec13
I just did this tonite, we took way over the time you posted here but we got it welded and stuff too. Very hapy with it over all, but disapointed after hearing it with nothing after the 3rd cat.
ih8vtec13 is offline   Reply With Quote
Old 04-07-2006, 02:29 AM   #3
jedimaster
Yeah, it's like when I changed my downpipe and listened to the exhaust with just the turbo and man it sounded weak with the rest of the exhaust attached
Old 04-07-2006, 03:19 AM   #4
LGT Chris
Are there real no exhaust options for the OBXT? It is probably the same template frame to build the exhaust, but your muffler and tip options are going to be in the crapper given that they point down and not out the back.
LGT Chris is offline   Reply With Quote
Old 04-07-2006, 04:29 AM   #5
Drift Monkey
LGT.org resident p0st wh0r3
Drift Monkey's Avatar
Send a message via AIM to Drift Monkey
Catless TBE FTW!
DriftRyders Australian Rally Farm
Drift Monkey is offline   Reply With Quote
Old 04-07-2006, 12:44 PM   #6
jedimaster
I use a stock LGT wagon setup with longer hangers- couldn't stnad the limp **** look of the turn down tips.
Old 04-07-2006, 12:49 PM   #7
ih8vtec13
ROFLMAO!!!!!!!!!!!!!
great pleas no comparison potos out of the BB fourm
Old 04-07-2006, 12:52 PM   #8
Drift Monkey
James has this done but I can't even tell with his two muffs in the way...
Old 04-07-2006, 01:05 PM   #9
ih8vtec13
It does sound better then with it in. I needed to get some stuff with my friend and we were thinking that one of those Cherrybomb mufflers they had in autozone may be pretty cool to put in place of the silencer and run straight pipe back no muffs. Quiet it a little and lose weight via mufflers. Any thoughts on that?
Old 04-07-2006, 01:13 PM   #10
Bu11dogg2
Super Moderator
Bu11dogg2's Avatar
Send a message via AIM to Bu11dogg2
I have heard this in person.
sounds awesome!!!
Bu11dogg2 is offline   Reply With Quote
Old 04-07-2006, 01:34 PM   #11
Drift Monkey
I meant Random james just to clarify, but yeah. Why not just make a straight pipe back with no muff? Even less weight! Looks weird without mufflers though...
Old 04-07-2006, 02:29 PM   #12
jedimaster
I've done that, but it sounds weird. At WOT, the exhaust hits the ground, then the bottoom of the car and makes this really weird echo.
Old 03-22-2009, 04:42 AM   #13
redstang98
What size piping would i use on a lgt?
redstang98 is offline   Reply With Quote
Old 03-22-2009, 09:04 AM   #14
2.5sbd
2.5sbd's Avatar
Yo was that first pic there before?
That is nasty. How long do you think that guy have them eating at his leg
Perrin UP, Cobb Catted DP, Cobb Mid & Y Pipe, Cobb AP V1, Tuning Alliance stg2 map, Cobb CAI, B&M Trans Cooler
2.5sbd is offline   Reply With Quote
Old 06-25-2009, 07:20 AM   #15
john
john's Avatar
Send a message via AIM to john
What the fsck is that first picture??
Look passive, be aggressive. Scare them.
john is offline   Reply With Quote
Old 06-25-2009, 10:09 AM   #16
The Jedi strikes back.
Old 08-16-2011, 06:34 PM   #17
04/2.5gt
i have 3 cats on my car does anyone think that removing one will make it much louder. i want my boxer rumble. sorry for stealing ur post
nasty nate strikes again!
04/2.5gt is offline   Reply With Quote
Old 08-17-2011, 04:12 AM   #18
It will probably make it just a little louder, but what really caps exhaust sound levels is the muffler canisters. Without changing/altering those, it'll be hard to really bring out the "Boxer Rumble."
Old 08-18-2011, 09:37 AM   #19
^^^ Yep. Cans first, then each cat you remove after that will make it just a touch louder.
