LegacyGT.org
LegacyGT.org (https://www.legacygt.org/forums/index.php)
-   Braking (https://www.legacygt.org/forums/forumdisplay.php?f=17)
-   -   brake problems help! (https://www.legacygt.org/forums/showthread.php?t=2895)
0306lgt 08-15-2014 07:36 PM
hey guys whats going on i have 03 legacy gt 5 speed manual last week i removed the heads sent out for milling and valve job had int manifold polished replaced all gaskets and seals in the front of the motor timing belt water pump etc my problem is now the car is back together and sounds and runs great but i have no brakes at all unless pressing to the floor very hard i bled the brakes multiple times and all fluid levels are good no leaks as far as i can see so i dont know what else it could be the only thing i removed at all that had anything to do with the brakes is the booster hose what could this problem be i am able to pump the brake pedal with the same resistance over and over again whether the car is running or not the pedal is very stiff and brakes were fine before the job i did any suggestions? thanks
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
