power sreering or power steering rack - LegacyGT.org
Old 11-09-2014, 01:58 PM   #1
knew541
Default power sreering or power steering rack
Having a problem with my steering only when at a stop and I turn the wheel I have a sound that sounds like either the power steering pump or the power steering rack is going out but if I'm moving everything moves fluently
I already checked the fluid level and the ps and it was a little lowbut did no difference in the sound when I filled it up
The sound is like a loose growling of the tires turning
knew541 is offline   Reply With Quote
Old 11-24-2014, 01:46 PM   #2
avilesmarco
I changed the Power Steering and alternator belt and the problem was solved. Trust me. 10 dlls problem if you change it.
avilesmarco is offline   Reply With Quote
Tags
power steering, power steering rack, ruf sound
