NHTSA Recall 14V311 - SUBARU / 2005-2014 - Brake Lines may Fail due to Corrosion - LegacyGT.org
Go Back   LegacyGT.org > Legacy Owner's Lounge > Warranty/TSB Info
Old 07-03-2014, 07:41 AM   #1
Default NHTSA Recall 14V311 - SUBARU / 2005-2014 - Brake Lines may Fail due to Corrosion
I got this e-mail from the NHTSA this AM:
You are receiving this message because you have requested to be notified if there is a safety recall regarding Vehicles from NHTSA's Office of Defects Investigation.
Please click on the following NHTSA Campaign ID links to view the recall information.
NHTSA Campaign ID Number : 14V311 Manufacturer : Subaru of America, Inc. Make / Model Years : SUBARU / 2005-2014 Subject : Brake Lines may Fail due to Corrosion
Thank you,
Recalls Subscription Team
Office of Defects Investigation (ODI)
National Highway Traffic Safety Administration (NHTSA)
U.S. Department of Transportation (DOT)
The ID Number hotlink took me to the following:
Report Receipt Date: JUN 10, 2014
NHTSA Campaign Number: 14V311000
Component(s):
Potential Number of Units Affected: 660,238
All Products Associated with this Recall
Vehicle MakeModelModel Year(s)
  • SUBARU FORESTER 2009-2013
  • SUBARU IMPREZA 2008-2014
  • SUBARU LEGACY 2005-2009
  • SUBARU OUTBACK 2005-2009
Details
4 Associated Documents
Manufacturer: Subaru of America, Inc.
SUMMARY:
Subaru of America, Inc. (Subaru) is recalling certain model year 2005-2009 Outback and Legacy, 2008-2011 Impreza and 2008-2014 Impreza WRX/STI, and 2009-2013 Forester vehicles, currently, or formerly, registered in Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, Wisconsin and the District of Columbia. Salt water could splash on the brake lines through a gap in the fuel tank protector, resulting in excessive corrosion of the brake lines. CONSEQUENCE:
Brake line corrosion may result in brake fluid leakage. Fluid leakage may result in longer distances being required to slow or stop the vehicle, increasing the risk of a crash. REMEDY:
Subaru will notify owners, and dealers will test the brake system by depressing the brake pedal and inspecting for brake fluid leaks. If no brake fluid seepage is observed, the affected areas will be rustproofed with anti-corrosion wax. If brake fluid seepage is observed, the brake lines will be replaced followed by rustproofing with anti-corrosion wax. These services will be performed free of charge. The manufacturer has not yet provided a notification schedule. Owners may contact Subaru at 1-800-782-2783. Subaru's recall campaign number is WQK-47. Note: This recall supersedes recall 13V-110 which applied to certain 2005-2009 Legacy/Outback vehicles. Vehicles that were remedied under the previous campaign still need additional areas rust-proofed. NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Also from the NHTSA page, there's the following linked documents:
  • http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM457986/RCAK-14V311-8690.pdf
  • http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM457674/RCDNN-14V311-3369P.pdf
  • http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM456823/RCDNN-14V311-4560P.pdf
  • http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM457319/RCMN-14V311-6734.pdf
Note that this is essentially the same recall as the one posted-up by blackfang, which took place last year; however, this is a new recall initiative, and supersedes the previous.
From what I can make out, this one is larger in scope (vehicles affected), but the technical stuff is the same.
Old 07-11-2014, 10:08 AM   #2
trailrated3277
trailrated3277's Avatar
I work at a subaru dealership this is essentially the same recall as before except they are using a different spray to coat and they are also focusing on a larger area of the vehicles lines.
trailrated3277 is offline   Reply With Quote
Old 07-11-2014, 03:00 PM   #3
^ Good to know. Thanks.
From the consumer side, all we know is that this recall expanded the affected models and model-years. It's good to know that they reformulated the spray and are looking at additional areas.
Old 09-28-2014, 04:52 PM   #4
blackfang
blackfang's Avatar
Send a message via AIM to blackfang
Yeah I have to take mine back in. I wonder if Subaru is using the same supplier for their spray as Toyota has had to recall the frame corrosion recall due to the spray..lol
My pics
09 Kawasaki Vulcan 900 custom
98 Camaro Z/28 HT A4- Lid, catback, Suspension mods, C5 wheels....300rwhp/308rwtq
07 Legacy 2.5i- SPT exhaust...daily driver
blackfang is offline   Reply With Quote
