Headers leaking oil! Exhaust issues - LegacyGT.org
Go Back   LegacyGT.org > Legacy Owner's Lounge > General
Old 09-13-2013, 10:36 AM   #1
jdizzle
Default Headers leaking oil! Exhaust issues
Couldn't find any info searching around but I was running invidia up pipe catless dp with magnaflow cb on cobb stage 2 ots map. The magnaflow was leaking at the dp and having fit ment issues. I had to unhook and unbolt the hanger by the rear o2 sensor in order to stop the leak but did not think ahead about bumps in the road. Without the support from the hanger I believe my turbo and up pipe bounced around and loosened up or stripped the exhaust manifold out of the block. I started to notice leaks and immediately put the stock dp back up with all the supports. From inspecting pretty much everything I found an oil leak just above the up pipe and looks like it was coming from the gasket from the headers to the block. Should oil even leak from there?
jdizzle is offline   Reply With Quote
Old 09-19-2013, 08:56 AM   #2
In most cases, if you have oil dripping on the UP, it's usually the valve cover gasket right above it. I've had to replace mine twice already and each time it had dripped on the the UP and could smell burnt oil inside the car. Inspect the valve cover gasket.
Old 10-03-2013, 08:22 AM   #3
jdizzle
It does look to be just the valve cover gasket
Old 10-11-2013, 07:41 PM   #4
The valve cover gasket is not a hard job to do, just time consuming. Have you replaced it yet??
Old 10-21-2013, 02:04 PM   #5
SubaRoo86
Does changing the valve cover gaskets involve pulling the motor?
SubaRoo86 is offline   Reply With Quote
Old 10-21-2013, 03:40 PM   #6
No, you can do it while it's still in. Matter a fact, I just did mine last night again, my passenger side gasket doesn't like me much.
Passenger side is fairly easy to get to, helps to have a long 10mm wrench.
Driver side requires unbolting the motor mounts and raising the engine (with a floor jack) a few inches to get the rear bolts off, and makes it easier to remove the coil packs at the same time.
Old 10-21-2013, 05:30 PM   #7
SubaRoo86
Sweet, im thinking its gunna need a changing cuz im getting some oil pooled up on the top of the motor in the vicinity of the manifold and the seam of the valve cover gasket. Does that sound like the same issue that caused you to change yours?
Old 10-22-2013, 09:09 AM   #8
Haven't seen too many with oil pooling up on top of the motor. Must of the time the oil will sep down to the bottom and coat the bottom half of the motor. I would recommend cleaning the infected area really good and watch it for a few days to get a better idea where it's coming from.
What year and model?
Old 10-23-2013, 06:37 AM   #9
SubaRoo86
its an 05' legacy 2.2. There was oil sitting on the top of the block in the channel with the "japan" stamp and going further back towards the firewall.
Old 10-23-2013, 08:27 AM   #10
How does the gasket look on the bottom of the motor? If there is oil there, then it's most likely the valve cover gasket.
Old 10-23-2013, 08:28 AM   #11
The 2.2 motors are slightly different from our 2.5 motors. Post a pic of the area if you can.
Old 10-24-2013, 06:20 PM   #12
SubaRoo86
its hard to get a good picture with the way the hood casts shadows.
Tags
exhaust, headers, oil leak
