Wanting to upgrade suspension - LegacyGT.org
Go Back   LegacyGT.org > Legacy Technical > Suspension, Handling, & Stiffening
Old 02-08-2010, 02:20 PM   #1
tmemz
Default Wanting to upgrade suspension
I have an 05 lgt and i am looking to upgrade the suspension on it in the next couple months along with getting new rims. I am new here and basically looking for something that overall is good and somewhat easy to do. I am not sure on which route to go with coil overs or struts and springs. But i am looking for advice and also looking not to spend crazy amounts of money but also looking for good results.
tmemz is offline   Reply With Quote
Old 02-08-2010, 07:06 PM   #2
How much u lookin 2 spend?
I would say u should start w/coilovers. There is an intro price on ISC N1s 4
$815 shipped. It's a new company here but they been in Australia 4 awhile.
http://lgtforums.com/forums/showthread.php?t=117450
http://www.legacygt.com/forums/showthread.php?t=129338
Old 02-08-2010, 07:22 PM   #3
tmemz
Wow nice...whats the stance on the ISN's are they any good.. they look great along with the bc's which tons of ppl seem to be buying. if i was able to spend under a grand on a suspension upgrade i would think that's a sure fire steal.
Old 02-08-2010, 07:43 PM   #4
Originally Posted by tmemz
Wow nice...whats the stance on the ISN's ?
They're ride height adjustable. Check the 2nd link in my post.
Old 02-08-2010, 08:00 PM   #5
What's more important, comfort or performance? And what's the most you'd be willing to spend if something were truly worth it?
Old 02-08-2010, 09:20 PM   #6
Coil overs are fairly easy to do since they are preassemble, just take out the oem struts and bolt in the new ones. Then adjust the ride height for proper stance.
Replacing just the springs is cheaper, but it will cost you more time to disassemble the struts using spring compressors.
Old 02-09-2010, 01:31 PM   #7
IMO coilovers aren't a very nice ride. I have experience with 3 different kinds and none of them ride as nice as the aftermarket springs on my car.
Old 02-09-2010, 04:38 PM   #8
2.5sbd
2.5sbd's Avatar
How difficult is it to remove old struts & replace with coil overs?
These coliovers seem to be a better option if the install is DIY
It seems like the same cost in the end if I bought $525 koni's and had them installed for an extra $300.
http://www.legacygt.com/forums/showt...=130257&page=2
Perrin UP, Cobb Catted DP, Cobb Mid & Y Pipe, Cobb AP V1, Tuning Alliance stg2 map, Cobb CAI, B&M Trans Cooler
2.5sbd is offline   Reply With Quote
Old 02-09-2010, 06:17 PM   #9
^^ Just outta curiosity SC what coilovers have u experienced?
Old 02-09-2010, 06:37 PM   #10
Tein Flex with EDFC, BC Racing, and Megan. The best ones out of those 3 were the Teins....but I just thought the EDFC was cool
Old 02-09-2010, 06:45 PM   #11
I haven't heard anything bad about the KW v2.
The cheapest I can find new is $1500 shipped tho.
Maybe next year when I get my refund.
Old 02-09-2010, 07:11 PM   #12
Not difficult at all.
3 Bolts on top
2 Bolts on the side - 1 bolt disconnect the brake line, the other is the ABS line
2 Bolts on bottom front
Slide out and reinstall new coil overs in reverse order.
Old 02-09-2010, 09:50 PM   #13
I have the Tarmac T1s which are essentially a mildly modified KW Variant 2 and I was told they'd be comfortable...they're not. My $.02
Old 02-10-2010, 05:47 AM   #14
For me, it's a no-brainer - I'd go with coil-overs, in a split second, for ease-of-install, adjustability, and the extra clearance it offers for wheel/tire combos.
Heck, compared to some of the higher-end strut/spring combos, the price difference isn't even truly all that much.
The problem, for me, specifically?
I live in the Rust Belt.
Since I don't typically obsess about washing my car, particularly in the winter, galvanic corrosion - or parts simply just sticking together from all that grime and grit - can be a problem.
For me, for the way I use Winky (true daily-driver, not tracked/AutoX'ed), coil-overs are thus a dream, a no-go due to real-world practicality concerns.
The same with two-piece brake rotors.
In my case, I'm trading practicality/maintenance for performance.
YMMV.
Old 02-11-2010, 09:29 AM   #15
But 4 me I'm not gonna get just springs cuz then I'm stuck @ that height.
I drive my car in the winter and I wanna be able 2 get up 2 @ least stock
height then after like March or april set that b!tch back down again.
Old 02-11-2010, 07:37 PM   #16
To each there own - I enjoy my Tein springs and there's no reason for me to have coil overs since mine is a daily driver and have no plans on racing.
Old 02-12-2010, 05:43 AM   #17
^ Be sure to get quality units, then, and also clean often.
That's, ideally, what I want, too - but a part of the equation is how corrosion and grime can affect the critical adjustment components.
I'm not averse to spending the money...but realistically speaking, I am unable to devote the time necessary to maintain the components.
Old 02-13-2010, 07:28 AM   #18
2.5sbd
2.5sbd's Avatar
I just bought koni sports and awaiting delivery $525 delivered
http://www.shox.com/appguide/shoxsho...ctsdisplay.php
Old 02-13-2010, 08:28 AM   #19
tmemz
i think i wanna go the coilover route
Old 02-13-2010, 10:48 AM   #20
^ KWs are going to be the way to go, if you face winter road-treatments:
http://www.kw-suspension.com/us/kw_inox_line.php
The salt-spray simulation is a good one, but remember that real-world road-use can be even more harsh. Starting off with the right components is a good way to insure that you'll minimize potential problems down the line, but even with "stainless," you'll want to clean your vehicle as often as possible, focusing specifically on the components of-interest.
Without proper maintenance, even the best components will fall to weathering.
