Noice while reversing - LegacyGT.org
Go Back   LegacyGT.org > Legacy Technical > Drivetrain
Old 04-04-2012, 12:13 PM   #1
Spec.B_Master_06'
Spec.B_Master_06''s Avatar
Default Noice while reversing
Hey all, me again with questions.
So when i hit the gas in reverse on a small incline leaving work i hear a (dont want to say grinding noice, but a friction noice) coming from the passenger front wheel. Could this be something to to with the bearings, or the transmission? Help? Dookie?
Spec.B_Master_06' is offline   Reply With Quote
Old 04-04-2012, 01:24 PM   #2
Wouldn't say transmission, since you pointed it out to the Right side wheel area. If it was the bearings they would make a squealing type sound. My guess is to inspect you brakes, if reversing, a pad could be rubbing causing a slight friction noise.
Is the sound consistence while going in reverse? Does it make any noise going forward?
Old 04-05-2012, 09:32 PM   #3
Spec.B_Master_06'
no noise while going forward and it is just when i start going into reverse. i will look into the brake pads tomorrrow. It feels like it is sluggish or catching. maybe a clicking? Also, i have been hearing a high pitched squeel not loud, but noticeable. Ideas with that as well?
Old 04-06-2012, 08:25 AM   #4
Hi pitch squeal would lead more toward the wheel bearings. A clicking sound would lead more to the CV joint. But first I would check your brakes, pull out the Slide Pins and make sure they move in/out freely. If one of the pins are stuck, this would cause part of the pad to rub against the rotor.
Old 06-03-2012, 12:08 PM   #5
GT_Garnet
I would also suggest wheel bearings, I've had these go out on several cars I've owned. I was able to pick up a Timken one for $89 on Amazon for the front. Wheel bearings make all sorts of noises, its never the same from one car to the next.
GT_Garnet is offline   Reply With Quote
