MBC install - LegacyGT.org
Old 04-07-2006, 04:57 PM   #1
Default MBC install
Short, quick and not really dirty.
http://jsalmi.com/car/boostcontroller/
Old 04-13-2006, 06:08 AM   #2
Ledfoot
What kind of hp figures do you see when you turn the boost to 15 or 16 psi as was done in the write-up?
Ledfoot is offline   Reply With Quote
Old 04-13-2006, 06:19 AM   #3
No idea. I've not dynoed/raced the car. Boost builds quicker, and you'll get 'part throttle full boost' due to the ECU & BCS being out of the loop.
Old 04-13-2006, 06:47 AM   #4
jedimaster
How long have you had this installed?
jedimaster is offline   Reply With Quote
Old 04-13-2006, 07:47 AM   #5
Drift Monkey
LGT.org resident p0st wh0r3
Drift Monkey's Avatar
Send a message via AIM to Drift Monkey
Part throttle full boost isn't a good thing last I remember...
DriftRyders Australian Rally Farm
Drift Monkey is offline   Reply With Quote
Old 04-13-2006, 08:25 AM   #6
Ledfoot
hmmmm.... if that's the case...what to do then???
Old 04-13-2006, 11:10 AM   #7
jedimaster
PTFB ftl.
Old 04-13-2006, 05:07 PM   #8
The ECU will compensate for the add'l airflow, as it reads a number of sensors when computing IPW. TPS is only 1. MAF, MAP, RPM, O2 sensors, etc... I've had a similar setup (same mbc) on my last few cars & it's not been an issue. No wideband in the car yet, but the plugs look great.
Old 04-13-2006, 05:07 PM   #9
I got the car March 1 and did put the hallman in about a week later.
