clutch issues - LegacyGT.org
Go Back   LegacyGT.org > Legacy Technical > Drivetrain
Old 02-21-2014, 08:32 AM   #1
wondersub
Default clutch issues
Hello, I have an 02 legacyGT 5 speed. last couple of days been hearing a noise when I release clutch in 1st gear and reverse, but not when shifting on the go (2-5) Sounds like throw out bearing to me. how long can they
make noise before they fail and can something worse happen if I keep driving? clutch works fine ( not slipping) but I am assuming that will be next. Also I have very slow tranny leak that drips on the exhaust, not a big problem except for the smell of burning gear lube. I can't seem to locate the source. It doesnt appear to be the rear seal. Any info would be great. thanks
wondersub is offline   Reply With Quote
Old 04-12-2021, 08:28 PM   #2
wesbrooklyn
Were you able to fix your clutch issue?
wesbrooklyn is offline   Reply With Quote
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
