General Reference thread. - LegacyGT.org
Go Back   LegacyGT.org > Legacy Owner's Lounge > General
Old 04-06-2006, 02:42 PM   #1
Bu11dogg2
Super Moderator
Bu11dogg2's Avatar
Send a message via AIM to Bu11dogg2
Default General Reference thread.
Here are some acronyms you make come across
Feel free to add some that I may have forgotten
Basic Terminology & Acronyms
4EAT – Four Speed Electronic Automatic Transmission
5MT – Five Speed Manual Transmission
5EAT – Five Speed Electronic Automatic Transmission (includes Sportshift)
6MT – Six Speed Manual Transmission
ABS – Anti-lock Braking System
AT – Automatic Transmission
ATF – Automatic Transmission Fluid
AutoX – Autocross
AVCS – Active Valve Control Sysem
AVLS – Active Valve Lift System
AWD – All Wheel Drive
BHP – Brake HorsePower (measured BEFORE transmission)
BOV – Blow Off Valve
CAI – Cold Air Intake
Cat – Catalytic Convertor
CEL – Check Engine Light
CF – Carbon Fiber
CO2 – Carbon Dioxide
Diff – Differential
DOHC – Dual Overhead Camshaft
EBC – Electonic Boost Controller
ECT - Electronically Controlled Transmission
ECU – Electronic Control Unit (engine control unit)
EFI – Electronic Fuel Injection
EG – Subaru 6-cylinder engines (up through mid to late 90’s)
EG33 – Subaru 3.3 litre 6-cylinder engine code (SVX)
EJ – Subaru 4-cylinder engines (early 90’s and newer)
EJ20 – Subaru 2.0 litre 4-cylinder engine code
EJ205 – Subaru 2.0 litre turbo engine (US WRX)
EJ22 – Subaru 2.2 litre 4-cylinder engine code
EJ25 – Subaru 2.5 litre 4-cylinder engine code
EJ255 – Subaru 2.5 litre turbo engine (US Forester XT, Baja Turbo)
EJ257 – Subaru 2.5 litre turbo engine (US WRX STi)
EZ – Subaru 6-cylinder engines (post EG series H6 engines)
EZ30R – Subaru 3.0 litre 6-cylinder engine code (BL/BP Legacy and new Outback)
FDR - Final Drive Ratio
FMIC – Front Mount Intercooler
FWD – Front Wheel Drive
H4 – Horizontally Opposed 4 cylinder (boxer)
H6 – Horizontally Opposed 6 cylinder
HID – High Intensity Discharge (headlights)
JDM – Japanese Domestic Market
LSD – Limited Slip Differential
MAF – Mass Air-Flow Sensor
MAP – Manifold Absolute Pressure Sensor
MBC – Manual Boost Controller
MIL – Malfunction Indicator Lamp (CEL)
MT – Manual Transmission
MY – Model Year
OEM - Original Equipment Manufacturer
RallyX – Rallycross
RWD – Rear Wheel Drive
SOA – Subaru Of America
SOHC – Single Overhead Camshaft
TMIC – Top Mount Intercooler
TT – Twin Turbo
UDP – Under Drive Pulley
VDC – Vehicle Dynamic Control
VIN – Vehicle Identification Number
VTD – Variable Torque Distibution
WHP – Wheel HorsePower
WOT – Wide Open Throttle
Thanks to Uncle Meat of the Cobb Tuning WRXForum.com
JDM (Japanese Domestic Market) Info:
Twin-Turbo: This is one of the most loosely used term. Everyone wants a twin-turbo because Japan has had it. It was a sequential setup with one turbo used for the low end, while a larger turbo was used for the high end. However, it wasn’t the most optimal solution being its cost, complexity, and between the 1st to 2nd turbo transition, there was a decent dip in power. It has been proven that other solutions are more cost-effective and produce better results in general.
More on turbo tech below.
B4: The term used for sedan since the 1998 model year.
B4 RSK: The name given to the turbocharged sport Legacy Sedan in the 1998 to 2002 model years. Remember, Japan has been even further ahead in model changes. They receive their models 2 model years (or MY) ahead of the U.S.
Note: Previous to the BE-generation B4 RSK, the sedan turbo models were called ‘RS’.
GTB: The name given to the turbocharged sport Legacy Wagon in the 1993 to 2002 model years that used the sportier Bilstein suspension.
S401: The ONLY STi production Legacy to date. This 2003 BE sedan model was produced in a short-run and were rather expensive. It contained much gear from the current year Impreza STi though mostly in drivetrain and brakes. It still retained a sequential twin-turbo setup though with a few more ponies. It also received some suspension modifications including Bilstein struts along with BBS 18x7” wheels.
Body Styles (by USDM MY):
Sedans
BC (1990-1994)
BD (1995-1999)
BE (2000-2004)
BL (2005-2009)
Wagons
BF (1990-1994)
BG (1995-1999)
BH (2000-2004)
BP (2005-2009)
Color-----------------------LGT.com ------- SOA abbrev.------Numeric Code
Obsidian Black Pearl ---- OBP ------------- BLK -------------- 2J
Satin White Pearl --------- SWP ----------- WHI ------------- 7J
Brilliant Silver Metallic -- BSM ------------ SIL -------------- 9D
Titanium Silver Metallic - TSM ------------ SXV -------------- 8E
Garnet Red Pearl --------- GRP ------------ RED ------------- 3J
Regal Blue Pearl --------- RBP ------------- BDR ------------- 5J
Atlantic Blue Pearl ------- ABP ------------- BLU ------------- 3A
--Additional Outback-specific Colors and Combinations
Champagne Gold Opal --- CGO ------------ GLD ------------ 9J
Willow Green Opal/
Moss Green Metallic ----- WGO? ----------- GRM ----------- U5
Brilliant Silver Metallic/
Granite Gray Opal -------- GGO? ---------- SLV ------------- K3
--Other Subie Colors (not on Leg/OB matrix)
World Rally Blue ----------- WRB ------------ ??? ------------ ??
San Remo Red ------------- SRR
Sedona Red Pearl (old) ---- SRP
Java Black Metallic -------- JBM
Solid Red ------------------- SR
Code-Vehicle-Engine/Trim-Transmission-Leather
6AA Legacy Sedan 2.5i MT5 na
6AB Legacy Sedan 2.5i 4EAT-S na
6AC Legacy Sedan 2.5i SE MT5 na
6AD Legacy Sedan 2.5i SE 4EAT-S na
6AF Legacy Sedan 2.5i LTD 4EAT-S na
6AG Legacy Sedan 2.5GT LTD MT5 Black
6AH Legacy Sedan 2.5GT LTD MT5 Taupe
6AI Legacy Sedan 2.5GT LTD 5EAT-S Black
6AJ Legacy Sedan 2.5GT LTD 5EAT-S Taupe
6AK Legacy Sedan 2.5GT LTD NAVI 5EAT-S Black
6AL Legacy Sedan 2.5GT LTD NAVI 5EAT-S Taupe
6AS Legacy Sedan 2.5GT LTD spec-B MT5 Red
6BA Legacy Wagon 2.5i MT5 na
6BB Legacy Wagon 2.5i 4EAT-S na
6BC Legacy Wagon 2.5i SE MT5 na
6BD Legacy Wagon 2.5i SE 4EAT-S na
6BF Legacy Wagon 2.5i LTD 4EAT-S na
6BI Legacy Wagon 2.5GT LTD 5EAT-S Black
6BJ Legacy Wagon 2.5GT LTD 5EAT-S Taupe
6BK Legacy Wagon 2.5GT LTD NAVI 5EAT-S Black
6BL Legacy Wagon 2.5GT LTD NAVI 5EAT-S Taupe
6CA Outback Sedan 3.0R LLBean 5EAT-S Taupe
6CB Outback Sedan 3.0R LLBean NAVI 5EAT-S Taupe
6CC Outback Sedan 2.5i LTD 4EAT-S Taupe
6DA Outback Wagon 2.5i MT5 na
6DB Outback Wagon 2.5i 4EAT-S na
6DC Outback Wagon 2.5i NAVI SE 4EAT-S na
6DE Outback Wagon 2.5i LTD MT5 Taupe
6DF Outback Wagon 2.5i LTD 4EAT-S Taupe
6DG Outback Wagon 2.5XT LTD MT5 Black
6DH Outback Wagon 2.5XT LTD MT5 Taupe
6DI Outback Wagon 2.5XT LTD 5EAT-S Black
6DJ Outback Wagon 2.5XT LTD NAVI 5EAT-S Taupe
6DK Outback Wagon 2.5XT LTD NAVI 5EAT-S Black
6DL Outback Wagon 2.5XT LTD NAVI 5EAT-S Taupe
6DM Outback Wagon 3.0R 5EAT na
6DN Outback Wagon 3.0R LLBean 5EAT-S Taupe
6DO Outback Wagon 3.0R LLBean NAVI 5EAT-S Taupe
6DP Outback Wagon 3.0R VDC NAVI 5EAT-S Taupe
Key
MT5: 5 speed manual
5EAT-S: 5 speed automatic with sport shift
4EAT-S: 4 speed automatic with sport shift
5EAT: 5 speed automatic
4EAT: 4 speed automatic
SE: Special Edition (base model+power driver seat+moonroof)
NAVI: Navigation System
LTD: Limited (base model+leather+power seats+moonroof+dual zone climate+upgraded stero)
Model Code Key
The codes change every model year
First Spot: The "6" USUALLY means the model year (ex; 6 = 2006).
Second Spot: The letter after the 6 denotes the body style by car (ex LEGACY Wagon is a "B" while OUTBACK wagon is a "D").
Third Spot: The last letter is actually alphanumeric. It starts with the least expensive model/trim/engine level in each different body style and goes up. It starts over at "A" with every body style
Bu11dogg2 is offline   Reply With Quote
Subaru and Legacy are trademarks of Fuji Heavy Industries and are used here for identification purposes oญnly. The comments and content are property of their posters.
Powered by vBulletinฎ
Copyright ฉ2000 - 2010, Jelsoft Enterprises Ltd.
